Clifford alarm with r/s issues
Old Jul 7, 2005 | 10:10 PM
DazzlinDave's Avatar
Car: '89 RS Camaro
Engine: 3.4l from 95 chicken car
Transmission: 700 AOD
Hi all !
I got a situaton where the remote starter doesnt work. The system in question is : Clifford Polaris 4( 4 years old,and now in second car), and the Clifford Intellistart 4(brand new).
I installed both myself. The actual alarm works fine. The problem is the r/s is not functioning correctly.The only time it will crank the engine,is when the main alarm is in valet mode.It will only crank for about 1 1/2 sec , not long enought to start the engine.
I have the vats bypassed with the correct resistor, and I have tried with the resistor removed and key in the ign, to rule out a vats issue.
The wireing has been checked by myself and others at least 5 times, and all is good,including grounds.
Here are the wiring diagrams:
alarm
remote
[edit]
the remotes have been programed correctly,as well as the rpm programing.
I figured maybe I got a bad box, but the acc delay works, so it should be working.Lights flash twice when trying the r/s,also.
Also, the car starts fine when not trying the r/s. [end edit]
ne help on this is greatly appreciated !!
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
