wiring up reverse lights
Old Jul 18, 2005 | 01:45 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
I look under my center console and just see a mess of wires. I just put a 5 speed into my car and need to wire up my reverse lights to it. I can figure out how to mate the two im sure completly different kinds of connectors im good with wiring i just have no idea what exactly i need to hook up to the wire on my trans
(for anyone who cares its a TKO-600 transmission)
Old Jul 18, 2005 | 11:15 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay, on your car there will be a back-up switch located on the left hand side of the transmission with two wires. pin "A" should be a dark blue wire going to pin "B5" of the firewall connector C100. From there it goes to pin "A" of the turn signal flasher and then goes to the "TURN/BACK-UP" fuse on the fuse pane. Pin "B" on the switch is a light green wire going to pin "C4" of connector C100. From there it goes to pin "G" of connector C208 which is located near the left hand quarter panel underneath the trim. From there it goes to the back-up lights.
camaro11j
Sep 19, 2018 08:49 AM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
