dizzy prob
Old Jul 21, 2005 | 12:25 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
dizzy prob
just recently my formula will "hiccup". as drive along it will cut out like someone turned of the key and the SES light comes on and then it will come back again like normal. it does this at random and sets no codes.
im "thinking" its the pickup inside the dizzy. when it happens all gauges stay solid as if nothing happened. also for reference, i was having a prob with it starting and thought it was the module and found it to be the 2 wires that go to the pickup. i tap te 2 wires, drop the cap and all is good.
hasnt done this in a while but im thinking this issue contributes to the current problem.
it also seems to do it upon fire up and when everything is still cold and will do it less or almost none after warmed up. it does it at mid-lower and lower RPMs also it seems.
a new pickup is about $11 but id rather be sure than pitch parts at it.
Old Jul 22, 2005 | 11:39 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Based on the info that you gave, I would definitly say it's the pickup. Code 12 technically is "No Distributor Refence Signal."
So, bad pickup, no refernce signal, SES light with "no codes"
Old Jul 22, 2005 | 08:13 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
thats what some of the third gen list guys are saying as well. if time allows im gonna fix it this weekend.
school boy
Oct 22, 2015 11:47 AM
customblackbird
Oct 1, 2015 04:30 PM
italiano67
Sep 22, 2015 08:42 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
