VSS signal under dash? What connector/wire?
Old Jul 27, 2005 | 12:15 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
1991 Z28 w/305 TPI motor.
Need to tap into the VSS signal. Is there an accessible connector (understand: without disassembling half of the dash) inside the vehicle that I can easily use?
Did a search, did not come up with anything that would answer this particular question.
Thx
Lou
Old Jul 27, 2005 | 08:24 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i don't have a wiring diagram handy, but i think the connectors that tie the engine/ECM harness in with the car under the dash over near the ECM should work. seems like one side of the connector is white.
seems like i have seen you post you have a wiring book, if so that should have the wire you need listed.
Old Jul 27, 2005 | 09:09 PM
BigBadLou's Avatar
Engine: TPI
No wiring book here.
Thanks for the info, I'll check it out.
Lou
Old Jul 27, 2005 | 10:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is no connector under the dash for the VSS in your car. It is two wires (yellow & purple) that run straight to pin "B9" & "B10" of your ECM from the VSS in the transmission.
Old Jul 28, 2005 | 08:12 AM
BigBadLou's Avatar
Engine: TPI
Thanks man!!!!!!!!!!!!!!!!
Old Jul 28, 2005 | 07:53 PM
crapper_mekanic's Avatar
Car: 1985 Trans Am/ Recaro w/webbed headrests (AS5)?
Engine: Code F
Transmission: 700, shame, ain't it?
Axle/Gears: 3.27 Borg-Warner posi
VSS
Some older models have the VSS on the back of the speedometer.
Old Jul 28, 2005 | 08:17 PM
DENN_SHAH's Avatar
thanks again Trickster, i don't know why but i was thinking he was needing to tie into the output signal from the the ECM
maybe it was the dozen or more questions i was answering for someone in a live chat for their cruise control.
it seems the older i get, the more i have a one track mind,...
$750 L98
Feb 1, 2025 02:25 PM
Vintageracer
Sep 24, 2017 12:34 PM
thunder57
Nov 7, 2015 02:28 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
tattmann
Sep 27, 2015 05:20 PM
