Steering Column Wiring Pics
Old Jul 28, 2005 | 09:42 AM
Turboba's Avatar
Car: '89 TTA
Guys,
As the Subject header says, If anyone could post or send me some good quality under dash pics, Driver Side.....Like a dummy, when I replaced my Ignition Switch I un-plugged everything and dropped the Column, but I meant to take a PIC first to make 100% sure that I got EVERYTHING buttoned up right...well I didn't and I want this to be perfect, I have the factory Manual, but other than the column schematic,and a few Component Location views, it's pretty vauge.
Thanks In advance!!
Old Jul 28, 2005 | 09:11 PM
Turboba's Avatar
Car: '89 TTA
I know I'm asking a lot..but....I will be ETERNALLY in your debt if Someone could these or E me!!!
Again..THANKS in Advance!
Old Jul 30, 2005 | 01:53 PM
Vader's Avatar
Does your column have an air bag?
Of what are you unsure, specifically?
Old Jul 31, 2005 | 07:12 AM
Turboba's Avatar
Car: '89 TTA
Vader,
Thanks, no Airbag, it's an 89 TTA, but I did actually get everything more or less back into place...what happened is that I was blowing my Main Fusebox power Fusible link(it blew once, replaced it and it blew again), the one on the Red wire that comes in through C100, and goes to the S200 splice to the Ignition Switch and Convience center...so I took Everything I could down under the column looking for a Chaff/break on that wire, and of course EVERYTHING looks perfect...so I replaced the Ignition switch..and removed the Power Accecories Circuit breaker..and more or less buttoned everything up..and I've been running the car for an hour or so....
and looking at the Fuse Link that previously popped and it looks good....
also while it is running i tried gently moving around the under colunm wire harness to see if I could 'ReCreate' the short but nothing occurred....
Soooo...maybe it was the Ignition Switch??? The Circuit breaker(perhaps as you had mentioned it wasn't doing it's job, and let the short through,ie. the door lock modle wire or power windows wiring has a break..)??? Thoughts????
Thanks again....(PS I still could use some pics if you have any....)
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
evilstuie
Feb 28, 2016 03:33 PM
Bull86
Aug 10, 2015 05:43 PM
