door locks
Old Jul 31, 2005 | 07:04 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
door locks
my locks dont work. i bought a new door lock relay thinking that was the problem but its not. i can hear the relay clicking when i push the lock button but the actuators dont pull in or out. i am getting voltage to the actuator (i tested with a test light but not a meter) and i hooked the actuator straight to the battery and they work so its not the actuators. what is the voltage supose to be at the actuators. is it a full 12v. anyone have this problem before.
Old Jul 31, 2005 | 07:11 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Should get the full 12 volts. I had trouble with mine, the lock mech. and rods were really stiff and hard to move, lubed it all up real good and worked fine after that. That lock relay is reversing relay, sort of tricky but if yours is a factory setup, that shouldn't be the problem if you have voltage at the lock motors.
Old Jul 31, 2005 | 10:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Smoke, Have you checked to see if the rods are bent, binding, or improperly installed?
Old Aug 1, 2005 | 12:16 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Double check the spring coil on the doors them selves they hold the locking rods in place,they have tendency to rust up and not give either!....its best to hit with wd-40!
Old Aug 1, 2005 | 12:48 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just out of curiosity, what spring coils are you referring to here. I have removed several of these actuators and rod linkages and do not remember these spring coils. They are not shown in my manuals either.
Old Aug 1, 2005 | 12:48 PM
sheltonw3's Avatar
Engine: Classified
Its ribbited to the doors interior panel,I found out the hard that this item was needed for when I was installing power locks and it holds the power actuator rod in place and if they rust, they can get REALLY stiff and not move!
Old Aug 1, 2005 | 02:45 PM
smokefan's Avatar
to clear things up a bit. i have an extra set of actuators also. i tested them with the battery and they move in and out fine, i hooked the actuators to the wiring in the car and nothing works, just hear therelay clicking. i checked voltage with a test light and i am getting power there when the switch is pressed. i tried with the actuators in the open and closed position and they dont work eiter way. so there cant be any binding problems with the rods cause they are not connected. any idea??
Old Aug 1, 2005 | 11:46 PM
sheltonw3's Avatar
Engine: Classified
It sounds like a bad power lead?....I had a simular problem and tapped off the power line from the trunk release power!....have you tried replacing the relay yet?
Old Aug 2, 2005 | 12:46 AM
smokefan's Avatar
yea its a new relay from the dealer. cost like 40 bucks or so. i have the power trunk disconnected cause i dont want anyone breaking in and stealing my stereo. but the locks dont work with it connected or disconnected
Old Aug 2, 2005 | 01:44 AM
sheltonw3's Avatar
Engine: Classified
have you tested the power cable that runs to the trunk lock?
Old Aug 2, 2005 | 12:31 PM
smokefan's Avatar
i havent tested it but i know the switch was working before i disconnected it
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
my86bird
Oct 23, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
