cruise control connector on TBI
Car: 89 camaro rs
Engine: 305 tbi
i have a 89 305 tbi auto. cruise hasnt worked AT ALL since i had it.
i read the tech article but it was a tpi car. i looked under the dash for anything resembling the connector this guy had pictured. i found something similar, only this has a 2-prong connector. the wires did run in the cruise switch's general direction.
i unhooked this, and ohmed it out (the same way the guy did on his tpi). i got infinate resistance. so...
1... was this even the right connector?
2... if so, does this mean the switch is bad?
thanks ahead of time...
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are two connectors under the dash for the cruise control. One is for the multifunction lever on the steering column. The second one has about four to six wires to it and hangs just below the steering column and runs through the bulkhead to the cruise control unit under the hood.
Car: 89 camaro rs
Engine: 305 tbi
Originally posted by Trickster
What color were the wires on each connector? You might have been looking at the wires for the VATS system on the lock cylinder.
pink w/ black stripe
grey w/ black stripe
grey
blue
those go into the female connector. the male connector has 2 prongs, and the wires are wrapped together in black.
does that make any sense???
if it were VATS related, my starter wouldnt engage with that unhooked, right?
Car: 89 camaro rs
Engine: 305 tbi
then i dont think its the VATS. because i did start the car with it unhooked... i wish i could find my haynes manual. i think my bro stole it. BTW Trickster, you have a PM!!!!!!!!!!!!
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
there is a cruise control module tucked up in the right side of the dash, thats probably what is wrong with your system
Car: 89 camaro rs
Engine: 305 tbi
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by dan_o_89_rs
right of the column or in the passenger side dash??? sry for the misunderstanding.
BTW, this is the same modue that I have referred to. Another BTW, did you get the E-mail I sent to that second address? Thread Starter
Car: 89 camaro rs
Engine: 305 tbi
The module he is referring to is mounted under the dash on the passenger side to the left of the ECM as you sit in the seat.
BTW, this is the same modue that I have referred to. Another BTW, did you get the E-mail I sent to that second address? TGO Supporter
Car: 1989 Iroc-Z
Engine: 5.7L TPI
sry trickster but i havent got it... i dont know what the deal is...im sure its sumthing with my account. is there anywhere online, that has these schematics posted???
Car: 89 camaro rs
Engine: 305 tbi
You've got e-mail!!!!!!!!!!!!!
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
