clocking the alternator?
Old Aug 18, 2005 | 03:07 PM
3liter914-6's Avatar
Hi folks,
I'm in the process of a 350 upgrade, and as part of it, converted from the old V-belt to the serpentine setup. However, now that I'm wiring up the engine, I discover that the 12V output on the back of the alternator interferes with my perimeter bolt valve cover (pre-87 style AFR heads). A friend mentioned to me that I can clock the alternator so that the output is in a different location, and a search shows that this is a pretty common procedure. What I didn't find from searching is what happens with the support bracket? My alternator has a stud on the rear where a thick iron bar attaches the alternator to the headers for support, if I clock the alternator then this changes the position of the stud, and I'm not sure I'll then be able to attach a support to anything.
I assume with all the interest in serpentine belt conversions, someone has run into this issue...any suggestions? I'm not necessarily averse to buying a new alternator, or taking mine to a shop to have it modifie, so suggest away.
Thanks!
Old Aug 24, 2005 | 10:27 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
there is a large plastic (sometimes metal) cyclinder that is in most homes nowadays i beleive it's called a trash can some times call a garbage can.that is were i put my bracket when i on my headers.i'm sure there was a good reason why the designers felt this brace was needed.the Alt. is braced pretty good with just the two mounting bolts.
Old Aug 25, 2005 | 11:00 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Ring the bell and give the man a prize
Old Sep 1, 2005 | 08:37 AM
Awesome. I couldn't wiggle the alt. with both bolts installed, but I wasn't sure if it'd cause problems. Sounds great guys. I just got back into town yesterday, picked up my alternator, it's re-clocked, rebuilt and 1 wire converted. $75 but I think it's worth it for an alt that fits and some peace of mind that this thing is going to last a while.
Thanks again
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
