wow this makes no sense....
went to go check my lights in the back tonight. left side...perfect. i go over to teh right side and i turn on the directional....and the light doenst blink it stays on. but whats weird is it doesnt blink green on the dash either. any ideas?
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
sounds like a bad bulb, easiest way to find it is to put the fourways on and look around the car to see which one isnt blinking.
what about fronts? if a front bulb is out it will do it too, also there may be more than one bulb on each side in the rear depending on which set of tails you have.
the front doesnt flash when i put the directional on. it is on and stays on like the back does. it is dim though. i DO however ahve a headlight that is out. but it is on the opposite side. that haev anythign to do with it?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by casebaseball205
hazards work...both flash in teh back and in teh dash...any other ideas?
well I dont think it would be the falsher since you said one side worked. I would look into why that one light is dim, could just not be in right or a bad buld itslef. Its something that is messing with the resistance of that one side because when the resistance changes in the circuit it can mess a flasher up. I would once again put the fourways on walk around the car and look at all the lights closely and see if one more ore is dim on the side that dont blink and then you need to find out why and I think it will lead you to your whole problem.
fixed.
ended up being a bad bulb somehow. it worked....but it was bad. i guess one of the flash filaments was dead. and the other onw wasnt. and the eone that wasnt was the filament that was causing it to go on. i dotn know. i switched the lights around and they all work now. hehe thanks for the help
mustangman65_79
Aug 11, 2015 03:17 PM
