Starter wiring
Old Sep 14, 2005 | 01:04 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Starter wiring
Hi...
Just finished my head gasket swap and was about to test start it.... No crank at all Crawled under the car to find the purple wire to the starter was laying against the starter, well easy fix put it on its connector and tried to start it again..........but nothing
Connected my voltmeter and checked--- no 12v when turning the key
So, I think I had a short when the cable was against the starter.
I need a wiring diagram of the starter relay and I will check for power there but otherwise I guess the fuseable link near the starter need to be replaced.............
Can I but a regular fuse insted, if so what size.........?
Old Sep 14, 2005 | 01:16 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
The purple wire should attach to the solenoid. And you can buy fusable link kits at most auto stores, you just cut out the old ones and crimp them in.
Old Sep 15, 2005 | 08:00 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
check the starter relay behind the drivers side kick panel. That's where the purple wire gets it's signal from .
Old Sep 15, 2005 | 09:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you reconnected the purple wire, which post did you put it on? The small post marked "S" or the one marked "R"? It should go on the one marked "S". Just a thought!!!!!!!!!!
Old Sep 15, 2005 | 11:44 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Checked the fusible links- OK
Checked the Relay- it clicked so Ok
Checked for power at the relay- Nothing....
Traced the power wire to the relay to my Alarm (DEFA Patriot) and I dissconnected it and the car started direct.........
/N.
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
