gauge problem
Old Sep 19, 2005 | 07:52 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
gauge problem
My gauges have always worked fine until recently. My MPH needle seems a little sluggish. when i speed up it will go up to about 20 than stop, then it will jump up to about 23-24. It will do it again around 40. It is more frequent when I slow down. If I hit my dash it will jump sooner. should i get it recalibrated? I've never seen a problem like this so I dont know what to do.
Old Sep 19, 2005 | 08:34 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
Sounds like your cable is hanging up. Try lubing the speedo cable and see if the problem goes away.
Old Sep 19, 2005 | 08:55 AM
grimmcs's Avatar
Car: 91 Camaro
I took the gauges out and it has 2 electric plugs. 1 behind the MPH and 1 behind the RPM. Could it be a bad contact?
Old Sep 19, 2005 | 12:12 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
My bad, I did not see before that you had a '91 9electric speedo, not gear driven). It is possible that you have some dirty/bad contacts. Try cleaning them and reassmble with some dielectric grease.
Old Sep 19, 2005 | 03:43 PM
grimmcs's Avatar
Car: 91 Camaro
one of the bolts that hold it in was loose so it probubly was making a bad contact. Should work now. Thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
justin57
Aug 20, 2015 07:05 PM
