wont start when hot
Old Sep 19, 2005 | 01:37 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
wont start when hot
my 1986 trans am wont start when it gets warmed up after sriving awhile. if drive somewhere and then cut it off and trie to start it nothing happens until it cools off.i installed a new delco remey starter and the same thing happend. any advice on what to check for?
Old Sep 19, 2005 | 01:40 PM
Firebat's Avatar
it might not be an electrical problem. Check out your fuel pump. Disconnect the fuel line to your carb. Have a buddy try to start it and see if any gas comes out of the line.
Old Sep 19, 2005 | 01:42 PM
Firebat's Avatar
does your starter actually work when warm? i mean do you hear you're engine try to start or is there just nothing happening?
Old Sep 19, 2005 | 01:49 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
hot reply
it a carb when i say nothing no crank the engine wont turn over its like a kill switch has been activated. all the accessories come on but no engine crank about 45 minutes later it fires right off.
Old Sep 19, 2005 | 01:56 PM
Firebat's Avatar
i kind of doubt this is it but try a different battery. Maybe you dont have enough cranking amps in it or something.
Old Sep 19, 2005 | 02:09 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Do you have headers by chance? If so sounds like heat soak to the starter. A heat sheild over the starter usually solve this problem.
Old Sep 19, 2005 | 02:44 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
not start
where can i get a heat shield from
Old Sep 19, 2005 | 02:49 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Summit and Jegs should have them for you. I think Mr Gasket even makes them. This is a common problem with long tube headers on alot of cars.
Old Sep 19, 2005 | 03:12 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Yeah, Mr. Gasket makes an aluminum starter heat shield. You still might find that you need to replace your starter though. But the shield will help protect your new one.
You can also order it directly from Mr. Gasket.
Old Sep 19, 2005 | 03:49 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Autozone has a solenoid heat sheild, i think theyre about 5 bucks
Old Sep 21, 2005 | 03:59 AM
twarne's Avatar
Car: 1986 Iroc-Z
Cruzin Kaz was right about the heat soak. My '89 RS (w/out headers) did the same as well as my '76 Nova (w/headers) . A cure-all I've used on my Nova is mounting a remote starter relay. You can read about it at Nova Resource, they explain it pretty well. It's worked like a champ for me the past 3 years. Here's the link:
http://novaresource.org/starter.htm
I would only go to this if a heat shield fails to solve the problem (always start with the cheaper fixes!).
Old Oct 30, 2005 | 12:22 AM
Feniks9174's Avatar
Car: 91 Camaro RS Convertible
Engine: 10:1 355 L98
Having the same issue with my 91 RS. In high school it was a frayed wire to the starter and not carrying enough voltage, then a few years later it was the alarm's starter kill that was interfering, now with the new headers I'm getting heat soak...
The remote solenoid looks good, but it also looks like more work than I want to do if something cheaper and easier works. Question though, are heat shields a "one-size-fits-all" sort of thing or am I going to need to search around for something with a more specific design?
Sorry, late post...
Old Oct 30, 2005 | 05:54 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
shields will be specific for make of vehicle, as in GM, so it will fit many diff models...
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
