which ecm?
Old Sep 21, 2005 | 02:51 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
which ecm?
i have an 89 camaro rs originally with 305 tbi....i am pulling out the harness and have it completely free except for the fact that i cant get it throught the firewall...there is the rectangular mounting bracket in my way....does anybody know how i can get it out without cutting it? sorry about a pretty stupid question but its a real PITA
Old Sep 24, 2005 | 05:31 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
I think I know which rectangular mounting plate your talking about, it's behind the pass. side kick panel right?
On the inside of the car, there is a U-shaped pin that goes around the outside of the rectangle, you slide that out. If you have ever seen the connector of a fuel injector it's like that.
I think you pull it from the top. Look real close and you'll see it.
Flashlight helps.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
