Speed Buffer question
Old Oct 2, 2005 | 06:14 PM
BDK's Avatar
BDK
Car: '01 Z28 , '88 WS6
Engine: LS1 , LB9
Transmission: 4L60E , 700R4
I did a search and couldnt exactly find what i was looking for. There is a seperate 2-prong plug with a purple and a yellow wire that goes into the buffer box. If im not mistaken, its for the sending unit. But when I look, theres another "Yellow and purple plug" just dangling upon the wirey mess going to or from the ECU. It wont fit into the buffer. I am very very confused. Am I missing something important? Im trying to get this squared away cuz my speedo isnt working and the VSS is brand new. Thanks
The top 2 wires
Ill take some pics if needed. Thank you
Old Oct 2, 2005 | 10:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have a feeling that what you are looking at is the wiring for the clutch safety switch that would be used if you had a manual transmission instead of an automatic. If would serve the same purpose as the park/neutral switch. BTW, wiring for both automatic and manual transmissions were included in some models.
Old Oct 3, 2005 | 01:26 PM
BDK's Avatar
BDK
Engine: LS1 , LB9
Ok, thanks for clearing that up for me. :-D
Old Mar 27, 2007 | 08:08 AM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
Re: Speed Buffer question
Hi Trickster
Do you have any clue on what the signals out from the buffer box is.
I hav figured out this now, correct me if I am wrong:
The twin plug is the signals from the trans = witch is analog
The four wire plug is probably all output?
Is there no power for this box?
are there diffrent amount of pulses pr mile on the different outputs?
I need to know this to hopefully use this as a signal splitter for my custom set up. New ECM (holley 950 comander), TCI tansmission controller, and original speedo. I need to split VCC signal to the TCI and speedo. the VCC signal is not stong enough to feed both TCI and speedo.
Ingar
Old Mar 27, 2007 | 04:58 PM
chevy014life's Avatar
hey question : sory i dont want to steal the post its just a revevant question
on a 1986 iroc where is the VSS does it thred into the cable near the guage or is it part of the guage? i want to go aftermarket autometer guages and i was wondering about the spedometer hooking up?
thanks
87iroctheo
Dec 4, 2016 11:47 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
djmarch
Aug 11, 2015 10:22 AM
