Fog Lights Wont Stay On
Old Oct 2, 2005 | 07:51 PM
Shake Zula's Avatar
Car: 1986 Olds Cutlass Supreme
Transmission: 200-4R
Axle/Gears: good question...
Did a search and found this a fairly common problem, especialy on 1990's. Fog lights work but the button has to be held in. In all the posts I couldnt find a clear solution to this problem though. Whats the answer?
Old Oct 3, 2005 | 11:47 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
From what you have described it sounds like you need a new fog light switch.
Old Mar 23, 2007 | 04:45 PM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Re: Fog Lights Wont Stay On
Whoa, old thread! Same here, have to hold the switch down in order for them to stay on (1990 firebird). Is the switch supposed to stay in a differnet (..on..) position or does it trigger something then pop back out (..off position)....did that make sense?
Old Mar 24, 2007 | 04:42 PM
TransAmman87's Avatar
Car: 90 Trans Am
My bird does the same thing... the switch has already been replaced and the grounds were checked too. Its almost like the circuit gets too hot and shuts off. I have no idea what to do either....
Old Mar 24, 2007 | 11:50 PM
Brads RS's Avatar
Has anyone tried checking the grounds on the fog light relay or the relay itself?
Old Mar 26, 2007 | 09:45 PM
Car: 1990 Firebird
Engine: 3.1
Got me a new switch (well used) on Ebay and now I have fog lights that stay on! Just for the record, there is an "on" and "off" position. The clicky thing on my old one must have broken that keeps it in the ON position.
Old Aug 23, 2007 | 09:11 PM
69 Six Pack's Avatar
Thanks for writing this. It saved me from trying to buy a new switch and alot of fustration. My switch wasn't staying depressed either and when I popped off the top I quickly realized that someone else had done this too but had put it back together backwards
A quick flip and snap back together and all it well. I have foglights at the press of a button.
Again your post really saved me alot of aggravation...
Thanks again!!!
Dave
Old Aug 23, 2007 | 09:16 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
My fog light switch was turning off too. I had to hold it in the on position.
I took the switch apart this spring to replace the red internal LED that had burned out. When I put the switch back together, it started working again.
The problem is obviously a mechanical issue with the workings of the switch, but I don't know exactly what I did to get it working again
Old Aug 23, 2007 | 09:55 PM
Car: 1990 Firebird
Engine: 3.1
Glad I could help!!!!
GTAman
Mar 15, 2019 11:40 AM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
mustangman65_79
Aug 12, 2015 06:39 AM
