Headlights and Radio
Old Oct 4, 2005 | 05:35 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Whenever my headlights are on my radio pops when I change the channel or turn it on or off. It doesnt do it when the headlights are off though. Its the factory radio and I've never touched the any of the electrical. Anyone have the same problem or advice for a cure?
Old Oct 4, 2005 | 08:43 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
i have no idea, but what kind of radio is it???
Old Oct 6, 2005 | 04:40 PM
2slow5.0's Avatar
Car: 91 Formula
Its the stock ac delco. I pulled it out and tried a jvc that was wired for the car, but it did the same thing. I'm thinking its a ground somewhere,but have no idea where to start looking
Old Oct 10, 2005 | 12:26 AM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
check to make sure your ground strap that mounts on the back of the drivers side head is not broken.
Old Oct 10, 2005 | 01:31 AM
Firebat's Avatar
if you have no ground you're radio wouldn't turn on at all. It would be just like not hooking up both ends of a battery.
Does your voltage go down a lot when you turn on your headlights? I've never heard of this problem. By the radio popping do you mean the speakers popping and does it happen no matter what volume you have it at or is it louder when the volume is turned up? Does your radio put regular audio to the speakers with the popping or is it just silent with popping?
Old Oct 10, 2005 | 11:57 AM
Originally posted by 2slow5.0
Its the stock ac delco...
interesting... tape deck with eq?
Old Oct 12, 2005 | 04:10 PM
2slow5.0's Avatar
Car: 91 Formula
Its just a regular tape deck, factory GM, what came in the car new. I don't think it has anything to do with the radio because it still does it if I use a different radio.
Old Oct 16, 2005 | 02:47 PM
o no i just am lookin for the high end stock stuff that works...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
