Internal left turn signal light stays on
Old Oct 17, 2005 | 03:55 PM
MKnight's Avatar
Hey guys,
Was hoping someone may have had some insight into this issue I have. When I turn on my pop-up headlights, the left turn signal light stays on, not flickering, just solid. I got out of the car and checked and the left turn signal doesn't turn on outside, it's just the light internally that stays on when the headlights go up. Could this be a grounding issue? I have only had the car for a little over a month and I bought it like that. If it is a grounding issue, where do I even start?
Old Oct 17, 2005 | 07:42 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Ive had this happen to me once before, it just means that one of the turn signal lights on the left side are burned out, so just turn on your hazzards to find out which one it is and replace it
Old Oct 17, 2005 | 07:45 PM
MKnight's Avatar
Thanks!
Old Oct 18, 2005 | 07:00 PM
Old Oct 20, 2005 | 01:16 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Is this when you have the lights on or not??
If so, check to see if one of your wires is stripped or unhooked. Mine usually does this if one of the three wires going to it gets unhooked.
That is since I have them wired spearately, cuz I moved them.
howeve, the same thing should apply. Just check the wires, its mostly their fault.
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
