Blower motor won't shut off!! HELP!!
Old Oct 19, 2005 | 11:38 AM
86305bird's Avatar
Car: 1986 firebird
Engine: 5.0 liter
ok so i have a 1986 firebird 305 automatic ...anyways the other day im driving around and i notice that for some reason my blower motor won't shut off...no matter what position the switch is in...so i figure wtf i'll just shut the car off and the blower will shut off...but NO!
i shut the car off and the things still going.....
i havent had a chance to really check it out yet but i also don't know where to start...i had to go to work in my other car so i just left it and the thing killed my battery.....
any ideas ? i really don't know where to start and any help would be appreciated...ive messed with the ignition switch to see if thats not shutting off but to no avail
thanks
matt
Old Oct 19, 2005 | 11:54 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
I would start by unplugging the power to the blower motor (it's at the rear of the pass fender). Charge up the battery and get out the voltmeter. You will have to test some wires to see why it's got juice all the time. Crossed wire, bad switch, short, etc. Having a wiring diagram would be helpful if the problem isn't obvious.
Old Oct 19, 2005 | 11:57 AM
86305bird's Avatar
Car: 1986 firebird
Engine: 5.0 liter
could it be a shorted out relay or somethin?
Old Oct 19, 2005 | 12:00 PM
86305bird's Avatar
Car: 1986 firebird
Engine: 5.0 liter
o yea,almost forgot... i just put a cd player in the thing....didnt use a wiring harness adapter....just did alot of wire testing....any way that could have somethin to do with it...i dont have the loot to score a voltometer
Old Oct 19, 2005 | 12:37 PM
Lo-tec's Avatar
Did the blower motor work fine before the CD install?
...and what did you use to test the wires? All you need to know is whether or not the wire is hot or not. A test light would also work.
Old Oct 19, 2005 | 06:07 PM
86305bird's Avatar
Car: 1986 firebird
Engine: 5.0 liter
o yea worked perfect at allspeeds
Old Oct 20, 2005 | 08:06 AM
Lo-tec's Avatar
If it worked fine before you installed your CD player, and now it doesn't, I think you screwed up some of the wiring installing it. Unwire it and see if it fixes your problem.
Old Oct 20, 2005 | 01:19 PM
86305bird's Avatar
Car: 1986 firebird
Engine: 5.0 liter
undid the harness connector from the back of the deck....still nada..and it worked fine the day of the install...the whole blower motor incident happened the day after..i dont think the two are related
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
slade5612
Aug 11, 2015 07:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
