need help matching up wires
Old Nov 4, 2005 | 09:17 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Ok, im not the most advanced electronics guy, but heres the deal im swaping in the entire 4th gen wiring harness and need to know which wires attach to the 3rd gen wires for the following:
1. Third brake light? which of the wires is pos and which is neg?
2. The tail light assemblys i need to know which wires goto what light and pos. and neg.
Old Nov 8, 2005 | 06:45 PM
Firebat's Avatar
why are you swapping the taillight wiring? it just seems like a lot of extra work for nothing, unless you have no wires there.
Really if you have all those wires there already for your turn signals and brake nights then no need to replace them.
one way to find out what the wires are is to get a cheap voltmeter. connect one end to the metal chassis of your car(aka ground) and the other to your wire. When you hit the brake, if you have the positive wire, you see a reading of about 12 volts on the meter. Just an example
Check out camaroz28.com's message boards for more on 4th gen stuff. If you have wiring from an LT1 (years 93-97) check out shbox.com.
nice to see a fellow nebraskan on the boards!
Old Nov 8, 2005 | 07:29 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
no im trying to tie my 4th gen wiring into the 3rd gen taillight wiring, and i cant really test it like you said becasue i dont have any of the wiring harnesses hooked up.
Old Nov 10, 2005 | 06:40 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Third gen:
Look at the connector al the way down where it says high level brake light. Its a yellow wire.
Old Nov 10, 2005 | 06:47 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
sweet thats what i was lookin for, i should be able to get it from that. hopefully that is haha.
Dirtbik3r's Avatar
Fourth Gen lights:
Old Nov 10, 2005 | 06:49 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
wow your the man! thanks alot
Old Nov 10, 2005 | 06:52 PM
Dirtbik3r's Avatar
Old Nov 10, 2005 | 07:01 PM
Dirtbik3r's Avatar
Sorry that last pic didnt load up. The internet stinks over here. If you really need the 4th gen one, PM me.
Old Nov 10, 2005 | 07:08 PM
Dirtbik3r's Avatar
Fourth Gen lights:
Jorlain
Aug 24, 2022 05:11 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Sep 8, 2015 03:38 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
apie2546
Aug 8, 2015 07:12 AM
