Wild voltage
Old Nov 21, 2005 | 08:33 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Wild voltage
I'm having trouble diagnosing a wild voltage problem with my 87 IROC.
When the brake pedal is depressed, the warning buzzer sounds, the instrument panel lights up, and the front marker lights come on. I replaced the brake switch, same results. The interior is stripped so I checked all of the grounds that I could find. The only ground not hooked up is the 3rd brake light.
Any suggestions?
Thanks!
Old Nov 21, 2005 | 10:06 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You have a bare wire or two rubbing against the brake pedal when you press it.
Old Nov 21, 2005 | 10:51 AM
Wadebryant's Avatar
I'll check that out!! Thanks for the feedback Trickster!
Elephantismo
Feb 13, 2019 12:51 AM
Marc Brown
Sep 28, 2015 01:40 PM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
