ignition cylinder lock removal
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
I have the steering wheel and column apart. Where do the two wires ( the vats system?) unplug from the ignition cylinder? Should I have it fixed or buy a new one. Will the vats reading need to be the same if I buy a new cyinder and key set?
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The wires run through the column to it's base, they unplug down there. There is no way to fix the wires. If purchasing a new cylinder, take a good ignition key with you to the dealer, as a new key is required when changing the cylinder. They will read the VATS code off it and cut a new key to match the new cylinder. It's that or bypass the VATS.
Guys at work use that, coat hanger, whatever. The wires are very thin and fragile, and easy to break. When I've done them, I drop the column down so it's easier to feed the wires through the loom with all the other garbage that is in there.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes those wires are fragile but they can be soldered or spliced together if there is enough wire available. Several members of this board have done this and so have I. As Lo-tec has mentioned, lowering the steering column and loosening those bolts that hold that shroud to the steering column makes it easier to guide the wire through.
Car: 1988 IROC
Axle/Gears: 2.77
So I can buy the new cylinder and splice the new wires to the existing? I think there will be plenty of wire to do that and I won't have to go any further into the column...
No, remove the old wires after disconnecting them at the base of the column. Run the new wires through the crap in the column, and plug them into the connector. There's no need to rig this job. Remove the 4 extra bolts and drop the column. It's about $90 for a cylinder and a key. If you f it up, it's gonna cost you another $90. Do it right the first time.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well, you see that little slot there to the left and slightly above the lock cylinder retaining screw? That is where it goes, that is the key warning buzzer switch.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
but yeah they just pop into the hole slot, cant miss it in there
the plastic part of it is what slides in
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
