Will this wire work for checking engine light
Old Dec 3, 2005 | 08:19 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Will this wire work to ground a diagnostic terminal and get info out of the ECM memory?
Old Dec 3, 2005 | 08:41 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
Yes. Anything thats a good conductor will work. Paper clip, bailing wire etc.
Old Dec 4, 2005 | 01:26 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Hehe yeah that should work, but you wont need all of it. The two terminals are like a few mm's apart.
Old Dec 4, 2005 | 08:18 AM
rjpbboi's Avatar
I know I wont need all of it, Im just gonna cut a lil like 4-5inch sliver off
Old Dec 4, 2005 | 08:19 AM
rjpbboi's Avatar
what are all the other terminals for if the only ones we really use are right next to each other?
Old Dec 4, 2005 | 08:34 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Downloading info to a scanner of multiple sorts.
Old Dec 5, 2005 | 05:40 AM
rjpbboi's Avatar
the wire didnt work, does this mean I need a new wire or my ECM just doesn't work?
Old Dec 5, 2005 | 08:31 AM
Vader's Avatar
That wire appears to be varnished. With that coating, the contact between the wire and ALDL sockets is suspect. Either scrape off the varnish from both ends of the wire, or find a piece of bare wire or paper clip.
As for the rest of the ALDL terminals, the diagram shows the possible connections. Not all these features are used on all ThirdGens.
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
