91 Z28 VATS won't work need guidance
Old Dec 14, 2005 | 12:27 PM
manbeastusmc's Avatar
I know this has probably been answered in another thread but sorting throught all that info. is a pain (i've been at it for an hour and a half). My car wouldn't turn over at times, but I would try it again a few minuintes later and it worked fine (Had power, no reason to suspect starter or seloniod). This was fine for a few months. Then it got worse and wouldn't work for a large part of the time. Security light would be on and all that. I called the chevy dealer and they said it was probably the key or keyswitch (tumbler) so i took them my key and they make me a new one and sold me a new switch. Put it in still did the same thing. I replaced the relay in the kick panel with one form a 89 irocz that worked in july until it was wrecked. Still didn't fix the problem. So that is where Im at what else can I do?
Started and everything works fine until this acts up.
Any help would be very appreciated.
Old Dec 15, 2005 | 10:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you thought about the VATS control module which is located on the driver side firewall below the defog vent ducts?
Old Dec 18, 2005 | 04:08 PM
I'll replace it with one on a 89 that i have (wrecked), and see if that works. thanks a lot
Old Dec 18, 2005 | 07:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you do that then you will need to get a get cut that is coded for that module from the 89 car.
Old Dec 20, 2005 | 09:09 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Take a multimeter and measure the resistance of that thing in your key. Buy a resistor or resistors of the same resistance and wire them into the two wires that connect to the ignition switch. That is what I did with mine and now I dont have to worry about the key making good contact with the terminals that connect it to the vats box. I guess you could pick out the chip in your key and wire that in if you ant find the resistors.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
