Car Stopped Running
Old Jan 10, 2006 | 11:23 PM
zrated57's Avatar
Car Stopped Running
The fan motor in my car stopped working because something was blocking it when it tried to come on. That burned up the fan motor, so I replaced that and then wired it back up. Now, when I turn the ACC. on the fan will always come on and will not shut off. Also, the car was running fine before the fan motor burned up and now when the car is started it will idle at 2000 RPM's and then die if you try to put it into drive or reverse? What could be causing those two situations. Could it be a bad computer? It's a 1985 Z28 Camaro with a 5.7 L TPI and 305 computer?? Any help is much appreciated. The dealership can't figure it out.
Old Jan 13, 2006 | 12:30 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Your fan relay switch might be stuck closed.
Old Jan 13, 2006 | 01:45 AM
zrated57's Avatar
The dealership finally pointed their fingers at the computer. They replaced it and everything works fine now. The fans, the idle, back to normal. The check engine light is still on, but they mentioned that's probably because the EGR has been removed so it's throwing that code.
Old Jan 13, 2006 | 01:56 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Re: Car Stopped Running
Originally posted by zrated57
Now, when I turn the ACC. on the fan will always come on and will not shut off...
with everything being stock, like the computer, the fan is supposed to come on when you turn on the a/c. otherwise the car would over heat
Old Jan 13, 2006 | 09:45 PM
zrated57's Avatar
Re: Re: Car Stopped Running
I'm sorry, I didn't mean A/C ... that was supposed to mean accessory (ACC.) position, like with the key on. Sorry for the confusion. I don't have A/C anymore, I wonder if the fans would still turn on even tho the compressor is gone??
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
