Positive battery wire P/N???
Old Jan 12, 2006 | 10:47 AM
92GTA's Avatar
Due to a hack job from needing a quick roadside repair from a part failure, lol, I need a new posititve battery cable.
It appears to be a very large piece and I need the whole thing, from the batt, to the alt, to the starter, etc.
Anyone know what the P/N is for my car (in my sig) so that I can order it from GMPartsDirect?
Also is there maybe a company that makes a direct replacement version of this in a larger guage or can anyone recommend a place that can custom make me one that would be top notch quality with all the correct GM connectors etc?
Thanks!!!
Alex
Old Jan 15, 2006 | 02:26 PM
92GTA's Avatar
Old Jan 16, 2006 | 10:46 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Don't have a p/n but go to www.newgmparts.com
Mecanical parts catalog:
>92 pontiac
>Firebird trans am gta
>electrical
>chassis electrical
>battery
>positive cable
> POSITIVE CABLE, 8 Cylinder, Fuel Inj Eng, MFI 91-92 $64.81 $49.26
Old Jan 16, 2006 | 11:00 PM
92GTA's Avatar
Thanks! I sent them a message in reguards to it. I'll post back what I hear.
Old Jan 16, 2006 | 11:28 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
I just checked my car folder because I remembered looking this part number up about a year ago. I found a printout.
Try Gm#12157285. The MSRP and sale price come up the same as Deadbird's post.
As of 12/12/04 www.gmpartsdirect.com had it for $30.55. Now I can't find it using a search.
Old Jan 17, 2006 | 09:32 AM
92GTA's Avatar
Thanks! Yeah that's the same P/N that new gm parts place lists. GMpartsDirect doesn't even show it anymore Sucks cause I have to order about $1K worth of stuff but some thing this new gm parts place doesn't have either. Sucks cause now I have to order from both.
Thanks for the leads though guys!
Old Jan 17, 2006 | 04:12 PM
92GTA's Avatar
CRAP!!!!!! That new gm parts site just emailed me back and said it's now disco for them too!
Old Jan 17, 2006 | 08:51 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Equivalent Part Number:
Delco 4SX33-1A
Try the AC/Delco part number. Its the same thing. Call around to who ever sells Delco stuff where you are.
Old Jan 17, 2006 | 09:31 PM
92GTA's Avatar
ACDelco.com shows that to be a negative cable used on 2002 L6 256ci GM models
Browsing shows part 2SX30-2 to be the correct negative cable for my 92 GTA.
However I can't find the positive yet
Old Jan 17, 2006 | 10:01 PM
Jade Grey's Avatar
Engine: 305TPI
Try an AC-Delco 2SD76X. That will get you from the battery to the starter side terminal.
The second number in the part number is the length in inches. Is the stock positive cable over 6 feet?
I found the part number last night while searching at www.autopartsgiant.com. A cross-reference to vehicle list by part number at delco's site comes up with a 4.3L Astro positive battery cable application though.
HTH
Old Dec 28, 2008 | 04:53 PM
macddy96's Avatar
Re: Positive battery wire P/N???
I have this part BRAND NEW!!!! in orginal packaging. let me know if your interested..
Old Dec 28, 2008 | 07:46 PM
92GTA's Avatar
PM'd.
Old Dec 31, 2008 | 07:50 AM
855speed's Avatar
Car: 1985 Iroc, t-top
Engine: 5.0L HO L69
Transmission: Mt 5 speed
Axle/Gears: 3.73 Non Posi, Alum Drums
Rock Auto has them. I ordered a pos and neg ACDelco for my Camaro a couple of weeks ago. Real Cheap also!
1992 Trans Am
May 10, 2023 07:19 PM
Jae992
Aug 27, 2015 09:07 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
