fuel guage moves alot
Old Jan 15, 2006 | 05:51 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
the guage is off on my 92....for example it reads 1/4 tank and i take a sharp curve and it will go to empty and sometimes the car will die and i have to stop and fillup...is there anything else besides the sending unit this could be?someone mentioned the ground does anyone know where the unit is grounded so i can check that out...thanks
Old Jan 27, 2006 | 11:44 PM
Firebat's Avatar
bad wire connections, corroded contacts....
Old Jan 28, 2006 | 12:05 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
No, its the tank. You need a 4th gen tank with baffles. The gas just swishes to one side, therefore a false reading (not the senders fault) and the reason your car sometimes stutters and dies.
Old Jan 28, 2006 | 12:06 AM
Firebat's Avatar
whats so special about a 4th gen tank?
Old Jan 28, 2006 | 01:18 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
you can fit a 4th gen tank up under a thirdgen?.. Might be something to look into then if it will fix the annoyance of the gas guage being messed
Old Jan 28, 2006 | 02:06 PM
dwillis's Avatar
Axle/Gears: 3:08
the fourth gen tank is plastic too right
Old Jan 28, 2006 | 03:19 PM
Firebat's Avatar
the 98-02 4th gen LS1's are plastic, The LT1s are metal
Old Jan 28, 2006 | 05:25 PM
dwillis's Avatar
Axle/Gears: 3:08
thanks for that info...im looking for one as we speak because my guage is stuck at 3/4 tank now and wont move at all...so if i have to change the sending unit i'll change tank,unit and fuel pump....what pump would i need to feed a mild performing 350 tbi with 350 truck tbi
Ghettobird52
Jul 5, 2024 11:18 PM
355sbcTPI
Aug 19, 2015 04:38 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
