Windshield wiper motor problem
Old Jan 23, 2006 | 04:56 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I swapped out everything from my '86 Firebird to my '87 GTA and now the windshield wipers won't work. Everything was working on the 'bird but now they only work on high and they move only a couple of inches from the bottom. I have tried two different switches (intermittant) and the switch that was in the 'bird which was non-intermittant and nothing.
Any help would be appreciated.
I have swapped out a 4th gen column, but repinned the connector under the dash thatthe wiper wires goto and made sure they were lined up like they should.
Old Jan 23, 2006 | 08:45 PM
Klortho's Avatar
Car: 1987 GTA
I keep seeing something about a drive pin, does anyone have a diagram that shows how the drive pin is supposed to be in conjunction with the pulse board cover and plastic piece?
Old Jan 24, 2006 | 06:53 AM
Klortho's Avatar
Car: 1987 GTA
I find it hard to believe that nobody has never had this problem.
Old Jan 24, 2006 | 03:00 PM
Klortho's Avatar
Car: 1987 GTA
Ok, now if I hit the washer, the wipers will work but only on high, if I let off the washer, it takes the wipers back to going only about 2-3 inches above the park position until I hit the washer again.
Old Jan 25, 2006 | 05:06 PM
Klortho's Avatar
Car: 1987 GTA
up
Old Jan 26, 2006 | 07:51 AM
Klortho's Avatar
Car: 1987 GTA
up
Old Jan 27, 2006 | 02:56 PM
Klortho's Avatar
Car: 1987 GTA
up
Old Jan 28, 2006 | 06:35 PM
Klortho's Avatar
Car: 1987 GTA
up
Old Feb 12, 2006 | 09:01 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Klortho I don't know if you've solved your problem,hope you have.I'm having a similar problem.This is from my '83 shop manual now so it may or not be the same wire color.If the wipers don't return to park or only work on HI ground the gray wire from the wiper-washer control.if the wipers park then replace or repair the wiper-washer control.
Old Feb 12, 2006 | 12:28 PM
327 iroc's Avatar
Car: ´86 Camaro IROC-Z/28 T-top
Engine: 327 (331)TPI
Transmission: th700r4
Axle/Gears: should be 3.73
I also got the same problem but my motor recently died so a new one will take it´s place, i hope then it will function properly.
I hope it works out fine for you
Old Feb 17, 2006 | 06:38 PM
87Ls1Camaro's Avatar
Car: 87Z28
Engine: 98 Ls1
Transmission: 4l60
Axle/Gears: 307
I just recently swaped a ls1 and 4l60 into my third gen and when i reinstalled the wiper motor and hooked it up im having the same problem you are kloth, They only worked in HI and only moved up 2-3 inches from the parked position. I went tho the volt tests and all my wires where working correctly I believe or I must have missed somthing. At first I thought I was missing a peice off the crank-to-arm linkage but I have all the right parts back on, just dont know what the deal is, have you solved the problem yet? I just ran into it yesterday
Old Feb 17, 2006 | 10:00 PM
Klortho's Avatar
Car: 1987 GTA
I haven't yet, really haven't had the time to fool with it, but when it warms up I'm going to check it out.
Old Nov 23, 2006 | 07:47 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
Anything new with this from anyone?
Old Nov 24, 2006 | 11:56 AM
Car: 87Z28
Engine: 98 Ls1
Transmission: 4l60
Axle/Gears: 307
Check all your wiper motor conectors, the wiring, and bulkhead connector on the drivers side firewall, make sure its clean and bolted in tight, ( c 100 ). I had the same problem and my bolt on the ( c 100 ) was lose from when I removed wiring for paint. Hope this helps
Old Mar 1, 2012 | 02:36 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Re: Windshield wiper motor problem
Did you ever find a solution?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
TheExaminer
Aug 26, 2015 04:59 PM
slade5612
Aug 11, 2015 07:19 PM
