high beam switch confusion
Old Jan 25, 2006 | 11:07 PM
persempremorte's Avatar
Car: 91RS CAMARO
Engine: 305 tbi
Transmission: stock 5-speed
i understand the linkage problem a lot of 3rd gens have in relation to the highbeam switch. if i dont want to tear apart my steering column, is it possible to rewire the highbeam switch under the dash to a switch ON the dash. Just want to relocate the switch. Hard to do?
Old Jan 25, 2006 | 11:38 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Not an answer, but a clarification of the problem...
Is this where the on/off rod piece which you pull towards you gets soft, and kinda spongy, and is therefore hard to turn the HIs on and off?
If so, I've got that oo, very annoying.
Old Jan 26, 2006 | 12:31 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The linkage isn't the problem. The switch either breaks or hex screws holding it loosen and make it out of adjustment. The Switch is under the entire dash (close to the brake pedal) and bolted to the column
You'll actually spend more time and effort rigging something than just replacing the switch and making it work like it should.
Dimmer switch.. red arrow..
Old Jan 26, 2006 | 09:23 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
What are the green and yellow arrows pointing too?
Old Jan 26, 2006 | 04:28 PM
Car: 91RS CAMARO
Engine: 305 tbi
So if the switch isnt bad, then all I should have to do is re adjust the nuts holding the switch in place?
Old Jan 26, 2006 | 10:50 PM
deadbird's Avatar
Engine: TPI 305/ v6
Green is the turn signal flasher. Yellow is the (in)convenience center that holds the door 'chime' and hazzard relay.
The switch should have slotted mounting tabs that allow for a minor amount of fine tuning to keep the slack out of the rod.
In my 87 and old 84 sc, it was the switch itself. My current 91 rs, it's the switch but, I'm to lazy to fix it and both high lamps have small holes in them as well. Even if the switch worked, the lamps don't
I rarely use high lamps anywas so it's not a high priority to fix.
(the above picture is from my old 84 SC camaro)
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
