vss buffer wire, please help Trickster
Old Feb 6, 2006 | 06:50 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Transmission: 5 speed
vss buffer wire, Trickster please help
Hi, i just purchased a 4th gen delco cd player with svc, and according to this How to on SCV 4th gen in 3rd Gen , we can make the svc work with our 3rd gen, i have an 84 z28 305H.O. (vinG) with 5 sp, and i can't seem to locate the wire (green with black stripe) or even vss buffer by my ECM, i know in 84, we have a mechanical speedometer, but where would the vss wire that i need to tap into it be? (according to the above link)or what color is the wire? thank you.
Old Feb 7, 2006 | 04:59 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
hi, i just did a seach and i think on the earlier 3rd gen(mine is an 84 305HO(vinG) with a 5sp, all orginal) they might not have a yellow vss buffer next to the ECM, if thats true, would there be a vss wire going into the ECM itself? and what color would it be, i have attach a pic of my ECM, any help would be appreciated it. thank you.
Attached Thumbnails vss buffer wire, please help Trickster-ecm-wires-003_resize.jpg
Old Feb 7, 2006 | 05:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The vss buffer was on the back of the speedo head for all cable drive speedometers to the best of my knowledge (take it with a grain of salt).
The buffered signal traveled a brown wire to the ECM.
Old Feb 7, 2006 | 07:14 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
hey thanks deadbird, do you think i can just tap into the brown wire or would that cause a problem with my speedometer?
Old Feb 8, 2006 | 12:12 AM
deadbird's Avatar
Engine: TPI 305/ v6
I wouldn't think so, as the ECM and cruise share the same wire off the buffered side (brown wire) of the vss. I cant see a 3rd wire, spliced in, hurting anything just for the rahdidio.
Old Feb 8, 2006 | 12:15 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
thanks again, when you say the buffer side, do you mean where it is plug into the ecm like in my picture? because in the link above they said tap into the green wire with black stripe. thanks
Old Feb 8, 2006 | 07:33 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Don't just go tapping into wires. You NEED some sense that your getting the right one. He said 'with a grain of salt'. If you can't get a little firmer answer keep looking or just go out and BUY A MANUAL for your car. But something about a brown wire sound right. And as long as you get the right wire tapping into it shouldn't be a problem.
Old Feb 8, 2006 | 11:06 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
thanks needaz, i am hoping to get more information about the wiring before i do anything, if anybody have info on an 84z wiring dialgram of the ECM, please let me know. thanks.
Old Feb 8, 2006 | 05:36 PM
deadbird's Avatar
Engine: TPI 305/ v6
I was referring to my 'knowledge' (or lack thereof sometimes) with the salt comment.
The vss is on the back of the speedo head for '84.
This is fact
Where it terminates at the ECM, I don't have a diagram of.
This is a cropped image of the cluster wiring. Notice the brown wire.. that is the buffered signal wire .
Blk/wht is ground
Pnk/blk is power from the gages fuse.
Old Feb 9, 2006 | 12:05 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
thanks deadbird, does that brown wire goes into the ECM? and what would be the number or pin that plug into? thanks again.
Old Feb 9, 2006 | 07:10 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Just run the wire up behind the instrument cluster.
Old Feb 12, 2006 | 11:25 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
thanks needaz
Old Feb 13, 2006 | 09:18 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Don't forget to post a follow-up if you get it working, or if you find that in fact your car has no VSS, here and in car audio land.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
marcusaw
Aug 10, 2015 08:13 AM
