rewiring speedometer
Old Feb 20, 2006 | 09:35 PM
transformula87's Avatar
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
I've searched for about an hour on how to do this and cant find exactly what I want.
Okay, I have stripped my car of its computer in anticipation for my new engine. I have made a new wiring harness for all my other gauges except for my speedometer.
I have a 1987 Firebird with an electric driven speedo. I found the two wires on the tranny which i'm assuming is for the speedometer, but do they go directly to the speedometer, or do they go through the ecm? If so, how do I keep my speedometer working without my ecm?
I found a couple things on something called a "speedometer buffer" or something. But I dont know where that is or what it looks like.
thanks for any help.
Old Feb 21, 2006 | 09:09 PM
Vader's Avatar
The VSS buffer module is strapped to the back of the ECM mounting bracket. (the big yellow thing):
Old Feb 21, 2006 | 09:37 PM
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
alright so if i just leave the buffer plugged in, the speedometer will work by itself without the computer?
Old Feb 22, 2006 | 12:19 AM
Vader's Avatar
On your '87, the VSS is mounted to the transmission. The speedometer does not need the ECM to operate (unless you have a digital dash Belinetta or GTA - NOT in 1987), and the VSS pulses are fed to the speedometer as well as the buffer box.
If you have a cruise control and intend to keep it functional, the brown output wire from the VSS buffer box runs to the ECM and the Cruise Control Module. You'll need to keep that wiring intact.
Old Feb 22, 2006 | 10:13 AM
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
alright...that makes sense. Thanks alot.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
