Alternator swap
Old Feb 21, 2006 | 12:28 AM
marcika's Avatar
Car: 86 IROC
Axle/Gears: 9 bolt Posi 3.45
Alternator swap
Hi, I have an 89 Firebird V6. The alternator is pretty much shot. I also have an alternator off of another third gen car, the only problem is that it is a 350. Does this matter? Can I just swap on for the other, or is there different types. Any help would be appriciated.
Thomas
Old Feb 21, 2006 | 12:36 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
as long as the new one is the same or higher output & it mounts up right it should be fine.
as far as i know all the thirdgens used the same type of alternator, some just had a higher output & there is also the different drive belt the later ones used, but you can swap the pulleys & maybe the spacer around if the other alternator used a different belt than what your car has.
Cornholio7979
Sep 20, 2018 02:31 AM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
Cleotiz
Aug 23, 2015 12:07 PM
Dialed_In
Aug 20, 2015 01:45 PM
