My tach reads double
Old Mar 21, 2006 | 08:43 AM
bullfrawg's Avatar
My tach reads double. It used to read correct. It is a 85 Trans Am 305. It has sat for about a year and i fired it up the other day and now the tach reads double. Does anyone know how to fix this?
Old Mar 21, 2006 | 05:18 PM
Firebat's Avatar
According to your sig - You have 2 trans ams. Sweet! Ok, start with swaping gauge clusters with your other TA. If the tach reads fine from the other one then your tach that was reading double was probably bad and should then be replaced.
Old Mar 21, 2006 | 11:43 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I had the same problem today. I went to jump my brothers car and I started mine up and noticed the tach was reading double. After he took the cables off. It was still doing it. He said I need to tighting the cables since they where loose. I did and it's back to normal like it was the day before. I don't know it that's your problem but it's worth a check. Adam :-)
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
