My new key
Old Mar 29, 2006 | 02:11 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Transmission: Automatic
My new key
so i replaced my old lock cylinder. My car has vats. the new key i have doesn't have a resistor pellet on it and so my car wont start. Can i get the same resistor pellet from my old key put on "the new key". And then my car will start.
Old Mar 29, 2006 | 02:31 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Chances are your new lock cylinder isn't set up for VATS so using the old pellet won't help anyway. Personally, I would disable the VATS but if you want to keep it, you'll need to get a VATS lock cylinder.
Old May 9, 2006 | 03:37 PM
91sleeperRS's Avatar
Car: Sold my Thirdgens, want another one
Engine: L98/TPI
Transmission: 5-speed
Axle/Gears: 3.45
how hard was it to replace your lock cylinder with the airbag steering wheel? because i need some advice before i change mine out.
Old May 9, 2006 | 04:55 PM
89RS&98Z28's Avatar
Car: 1989RS////1998Z28
Engine: 305////350LS1
Transmission: 700R4////4L60E
Do the resistor bypass and be done.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
