trans am cluster swap.140kmh-140mph?
Old Apr 3, 2006 | 09:24 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Does anyone know if I can directly swap out my 87 transam 140kmh cluster for an 140mph from a 90 transam without any issues or should i look for a higher kmh cluster.would there be any wiring issues?
Old Apr 7, 2006 | 11:40 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
does anyone have any idea if this is possible?
Old Apr 8, 2006 | 09:09 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
kmh is measured diffrently then MPH so I would imagine you could install it but it would need to be calibrated after installing it.
Old Apr 9, 2006 | 01:33 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
How would i be able to do that?
Old Apr 9, 2006 | 01:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They aren't measured any differently. A metric speedo is interchangeable with an english one.
I don't know if there are any differences between the 87 and 90 Firebird speedos though. They're both electronic so there might not be.
Old Apr 9, 2006 | 10:10 PM
Dragonfire383's Avatar
Car: 1986 Trans Am
Engine: 383 Stroker
Transmission: Turbo 350
I replaced my old "85mph" to a "140mph" and had no troubles. I think that the conversion process takes place in the circuit board that is connected the the speedo gauge, so make sure you change the gauge with the chip board. On my conversion everything seems to be accurate mileage, trip and speed. hope this helps. I'm not sure about the 87 to 90 swap though.
Old Apr 9, 2006 | 10:55 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Well im waiting for the cluster to be shipped.I guess all i can do is try it out and see what happens.worst case i can just stick with what i have.
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
