headlight problem, I'm stumped.
Old Apr 9, 2006 | 11:33 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Ok so I had a glitch that popped up on me all of a sudden last fall. I didn't realized how bad it was until this evening.
When I have the driving lights on with low beams, the right hand signal light is just barely lit on the indicator on the dash. With high beams the right hand signal light is fully bright. Also, using the turn signal to the right does nothing. With no lights on, everything seems fine including the right turn signal.
Today I went out and actually had a look at the front of the car with and without the driving lights on. I shot some pics, have a look below.
I've quickly gone through all the wiring, relays, and fuses and everything appears to be good. I've unplugged and plugged in all the lights and everything there seems fine to? This glitch started right after I got my car back from the shop in the fall, but they only worked on my suspension brakes and rear end (shocks, struts, sway bars, wonder bar, all new bushings, rear end, disc brakes front and rear, gear ratio, etc).
Ok this first shot is low beams only.. its hard to tell from the shot but the high beam lights are ever soo slightly illuminated.. like just barely glowing.
Old Apr 9, 2006 | 11:35 PM
Brisk's Avatar
This second shot is high beams on only. Driving lights are OFF. It is just as it appears, the passenger side and drivers side driving lights and passenger side headlights are dim. The park light on the front and the side amber marker light on the front fender is also out.
Old Apr 9, 2006 | 11:37 PM
Brisk's Avatar
This shot is low beams with driving lights ON. Now the high beam light on the drivers side is also dim
Old Apr 9, 2006 | 11:38 PM
Brisk's Avatar
High beams on with driving lights on.
Old Apr 9, 2006 | 11:39 PM
Brisk's Avatar
Only park lights on.. everything seems normal.
Old Apr 9, 2006 | 11:42 PM
Brisk's Avatar
Last image. Park lights on with driving lights on. Passenger side park light is dimmer then usual and passenger side driving light is dim. Also it is hard to tell from the image but the high beam lights on both sides are ever soo slightly on, just barely illuminated.
Old Apr 9, 2006 | 11:43 PM
Brisk's Avatar
I don't get it.. I'm stumped. Where do I start?
Old Apr 9, 2006 | 11:51 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
my firebird did that it was a ground & relay problem ....
Old Apr 10, 2006 | 12:10 AM
Brisk's Avatar
so was it a relay that wasn't grounded properly.. or? which relay was it that was giving you the problem?
Old Apr 10, 2006 | 12:19 AM
firehawk35's Avatar
Car: 88 GTA
Transmission: 700 R4
I had the same issue with a Blazer I own. turned out to be a bad ground on one light. the plug was not grounding to the light light itself. could wiggle the plug and the low beam would go from to back to bright and the high beams that were barley on would go out.. Had to change headlight plug to cure the problem permently.
Old Apr 10, 2006 | 12:47 AM
Car: 1985 TransAm
Engine: 5.0L TPI
no it was 2 seperate problems
1 realy had gone bad
and a poor ground at the headlight
Old Apr 10, 2006 | 02:19 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
try taking out each relay and cleaning them and remove the headlight switch and clean and check it.
Old Apr 10, 2006 | 02:27 PM
Brisk's Avatar
ok guys, thanks for the tips. I probably won't be able to get to it till the weekend, I'll let you know how I've made out.. hopefully this problem will be resolved!
Old Apr 15, 2006 | 04:40 PM
EdsSS's Avatar
Headlight problems
I just finished cleaning all the grounds on a friends 87 camaro. Same problems you are having. After cleaning and re-tightening the grounds they worked fine. Good Luck.
Old Apr 17, 2006 | 04:24 PM
Engine: 5.0L 305 H
the Fiero use the same kind of headlight system as the 3rd gen firebird/trans am here is a webpage with the pocedure of checking. it help me alot!
Troubleshooting the Fiero headlight system
Old Apr 30, 2006 | 05:20 PM
Brisk's Avatar
ok so I finally found some time to mess with it.. and fixed the problem.
the front right hand side 1157 bulb was in the wrong way and I found the ground on the right hand side right above the headlights has two wire leads to it.. one from the driving lights, one from the headlights. This ground was loose, heck it wasn't even finger tight. So I took it off, cleaned it up, retightened it, and problem solved.
Now if only I could figure out why my cruise control doesn't work...
Old May 1, 2006 | 02:13 PM
Engine: 5.0L 305 H
anyone know where i could get a new set of wiring for the headlights? i have replaced the switch, the relays and checked the motors, and i the headlights motors still only responed just a few times after i installed a new switch. im afraid its a short! and after the switch was replaced my dad (partial owner) has given up!
Old Sep 5, 2012 | 01:07 PM
Gary Simonds's Avatar
Car: 87 IROC-Z
Axle/Gears: 2:73
Re: Headlight problems
I have the same issue on 87 iroc . where are the grounds? is it the connector at the headlight?
thanks
Old Sep 6, 2012 | 06:41 AM
Car: 87 IROC-Z
Axle/Gears: 2:73
UPDATE: after air blowing and cleaning all connectors with brake clean. everything works as it should. also cleaned the ground connected to the car body.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
CORV3TT3
Aug 23, 2015 11:26 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
