NEED HELP WITH ECM WIRING
Old Apr 10, 2006 | 08:37 PM
morbidia
Guest
Posts: n/a
JUST CAME INTO MY POSSION IS A 88 CAMARO 305 TBI (CODE E) , THIS THING WILL NOT START..(NO FIRE OUT OF THE DISTRIBUTER.... I GUESS IT HASNT STARTED IN ABOUT 2 YEARS) I JUST HAD THE ECM TESTED & IT TESTED GOOD SO I GUESS MY NEXT STEP IS THE PICK UP COIL
ANYHOW MY QUESTION IS: WHEN I TOOK THE SPARK MODULE OUT I NOTICED THAT THE CONNECTOR FROM THE PICK UP COIL WAS KINDA SOFT & GLUEY & THE TWO WIRES COMMING OUT OF THIS CONNECTOR CAME OUT, ME BEING THE EXPERIENCED MECHANIC I AM DIDNT NOTICE WHAT COLOR WAS POS & WHAT WAS NEG.
I NOW HAVE THE NEG. AS YELLOW & GREEN AS POS.
IS THIS RIGHT
THANKS
PAUL
Old Apr 11, 2006 | 09:39 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Most wires coming out of the ECM are switchable grounds. The only yellow wire out of both connectors (C10) is your coolant temperature signal.
As far as the "green" wire goes... There are 2 choices. That's assuming this green wire is not striped.
D14 - Light Green - Injector 2 drive
C11 - Light Green - Map Signal
As far as I know, Without the yellow wire, your computer would just think it is -40 *F or *C outside. This probably will not effect spark. I'm not positive of the other 2 wires. I think that no MAP signal will cause the computer to close its EST circuit.
Old Apr 11, 2006 | 09:46 PM
morbidia
Guest
Posts: n/a
thanks for the reply; im a dumb *** i guess i mean the spark module by the distibuter there are 2 wires comming out of the pickup coil to this module 1 is green 1 is yellow which one is neg & whic one is pos.
Old Apr 11, 2006 | 10:10 PM
Dirtbik3r's Avatar
Lol, thats partially my fault as well. I was reading about your ecm and assumed.
I belive you're talking about the two wires that go from the distributer directly to the primary coil. I'de help you but alldata will not give me the wire colors or connector views. I don't believe either wire has a full 12v but both are positive.
Old Apr 11, 2006 | 10:18 PM
morbidia
Guest
Posts: n/a
THANKS AGAIN
stalkier
Dec 6, 2015 11:25 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
