Changed Hood and Now my Engine Bay Light Won't Work
Old May 16, 2006 | 09:50 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
I got rid of my stock hood and replaced it with a new fiberglass hood. But after the swap I noticed my underhood light stopped working. So I took out the bulb and tested the connection point to see if it was getting power. I used my light tester and it lit up as soon as I made contact. At that point I figured the bulb was bad (eventhough the filament was still in tact). I bought another pair of bulbs from the auto parts store and still no success, neither of them worked.
WTF is going on?
The light tester is saying the connection point is getting power, and I've tried three different bulbs all of which appear to be in perfect working condition.
I'm thoroughly confused. I'd appreciate any help.
Old May 16, 2006 | 10:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Fiberglass doesn't conduct electricity so good.
Old May 16, 2006 | 10:35 PM
1989GTABlown632's Avatar
Car: 1989 Pontiac Firebird Trans-Am GTA
Engine: Blown 632 CID with Nitrous
Transmission: TH400
Axle/Gears: 4:10
You will need to run a ground wire
Old May 16, 2006 | 10:57 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Okay. Thanks.
I'm not too knowledgable about electricity, so can someone explain to me why I need to run a ground wire if the connection point is already getting juice?
I don't understand.
Old May 16, 2006 | 11:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You've only got half a circuit there. The bulb used to be grounded through the metal hood. Now that you've put a fiberglass hood on, there's no ground path anymore.
1992rs/ss
Jan 31, 2025 05:10 PM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
Omega
Aug 10, 2015 12:46 PM
