Mechanical Speedo?
Old May 19, 2006 | 09:41 AM
j dezzy's Avatar
Car: 87 TA
Mechanical Speedo?
What years had mechanical speedometers? Getting rid of the 2.8 in my girlfriends camaro, and I'm getting rid of the ECM while I'm at it. So I've gotta track down a mechanical speedometer and tachometer. Thanks guys
Old May 19, 2006 | 10:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
In the camaro everything up to 89 is mechanical. The ECM has no affect on the operation of the speedo, so you won't need to change it anyway.
Old May 19, 2006 | 12:07 PM
j dezzy's Avatar
Car: 87 TA
Thanks.
Old May 19, 2006 | 06:36 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Not true. My 86 TA had a electrical speedo.
Old May 19, 2006 | 06:50 PM
j dezzy's Avatar
Car: 87 TA
Ok. The current speedo will work with no ECM right. But the tach won't will it...? The only way I'm keeping the ECM is if I got with TPI. The wiring in her camaro is screwed...it's been hacked and rewired over the years. I'm just gonna rewire the entire car while I've got the car stripped and bare...
Old May 20, 2006 | 03:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm sure it does, but a Trans Am isn't a Camaro. Either way, the ECM still has nothing to do with making the speedometer work.
Old May 20, 2006 | 03:29 PM
Jza's Avatar
Jza
Lol read the quote you quoted..
Old May 20, 2006 | 05:36 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Firebirds got electric speedo in late 85 or early 86.
Camaros in 90
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
