Help me, nothing is working
Old May 29, 2006 | 02:09 PM
Hermz28's Avatar
Car: 88 SC Camaro
Engine: 305 TBI
I tried to park my 88 305 camaro in the garage for memorial day weekend, and i went to turn it on and me engine started at first and then died. I tried to restart it, but nothing at all would happen. No radio, no crank, no nothing. My dome lights and headlights are the only thing that works. I do have an open air element installed, and i understand that for some people these things can cause problems... Any advice?
Old May 29, 2006 | 03:12 PM
precise86's Avatar
Car: 92 RS 25th Anniv
Engine: 305, V8, 5.0
Transmission: auto aka 700R4
Axle/Gears: 3.73 rwd
ewww, lets hope ur coil wire didn't make contact with the metal lower part of ur open air intake. If it grounds out then that would be bad...very bad
Old May 29, 2006 | 07:30 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
it wouldnt be that bad, all he would have to do is replace the fusible link at the starter.
Martin
Old May 29, 2006 | 08:02 PM
Hermz28's Avatar
Car: 88 SC Camaro
Engine: 305 TBI
1 bad third gen, i read the board that you posted when you were struggling with the same problems. My only question is: Where is the starter located, and where is the fusible link im looking for? I tried looking for it in the repair manual, but it didnt help at all.
Old May 30, 2006 | 02:52 PM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
the starter is located underneath the passenger side right by the transmission. it should have three wire going to the + side with fusible links which look like a cylinder plastic wraped around a red wire. splice each wire for an open circuit.
Did you install an aftermarket open air element?
Martin
Old May 31, 2006 | 01:45 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
I would say fusible links too. You can actually follow the wires in their wrappings from the positive battery terminal and they go along underneath the engine on the passenger side. I had some go out on the highway once.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
