I hear hatch relay clicking in the dash -- where is it?
Old Jun 2, 2006 | 02:19 PM
syc0path's Avatar
Car: '88 Trans Am
Engine: 305 TBI
Well since nobody seems to be responding to my other post, let me try a post w/ a title that more accurately describes what I need at this pt in the process...
I need to find the relay that is triggered when u push the hatch pop button in the dash. Yes, I have the diagram that is posted here on this site, but unfortunately my car doesn't match it. My car is an '88 Trans Am.
I unplugged a wire on the hatch motor. Now when I hit the hatch button, I can hear a relay clicking. I assume this must be the relay that triggers the hatch, becuz it only clicks when I hit the switch and it doesn't work if the ignition is on.
Now here's the problem... I can't find this f*ckin relay!! It sounds like it's coming from the pass side of the dash, so I took the hush panel and the little plastic piece above it off. But I still can't see anything... the only other thing I can take off is the dash pad. Or maybe it's coming from behind the radio or something... does anybody know where this relay is before I tear my whole dash apart????
Old Jun 2, 2006 | 03:16 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Passenger side of the dash under the trim panel that is under the map pocket. It is up in the dash a little. It is physically behind the map pocket. You just have to dig a little. If you unplugged the black wire from the hatch motor the release solenoid will not work.
Old Jun 2, 2006 | 11:53 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It is in the location Bingo describes on Firebirds. On Camaros it is below the center console adjacent to the gear selector.
Lon
BRoss99
Aug 10, 2025 05:08 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
andy74
Sep 3, 2015 08:41 AM
