battery or alternator problem?
Old Jun 14, 2006 | 02:06 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
i was driving today and when i came to a stop i notice my voltage gauge was really low (around 10v) and when i accelerated it would go up to about 12v and progressively float around, could the battery not be holding a charge or is the alternator not giving a good enough charge??? please help
Old Jun 14, 2006 | 02:22 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Most likely its the alternator. If I remember correctly the voltage gauge is reading the alternator output.
Old Jun 14, 2006 | 03:07 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
This is true. before you go to change the Alt tho, CHECK YOUR BELTS!!!!! All it could be is a loose belt and a $30 belt vs. a $100 alternator....you see what I am getting at. Also check all your connections, corrosion kills electrical flow. And also double check your gauge, the gauges in our cars are not accurate enough and many times have false readings. Use a volt meter, or DVOM (can get then at Sears or parts store for cheap, great investment), and with the car running and making sure the belts are good, place the leads accross the battery terminals and compare the reading to your guage. Also check your battery terminals for being loose or corroded.
Good luck, and hope it is cheaper than an alternator!!
Old Jun 14, 2006 | 03:52 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
also...
this problem just occured today, the alt always charged at 14v.. now all of a sudden the voltage is dropping at stops & returns to normal during acceleration- the belt's tight & the the terminals are tight too & clean.. would this most likely be the alt b/c they're both original equip & i was planning on replacing the battery & alternator anyway
Old Jun 14, 2006 | 04:17 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Take the alternator to your local auto parts store - they'll test it for free.
Old Jun 14, 2006 | 04:56 PM
BUt if the problem is intermittent then the parts store may not notice the problem with their equipment. If it is persistant then they will notice, and cheapest way is to bring it to them, otherwise sometimes they charge when it is still in the car. And if you really have doubts, replace it, or if it makes you feel better and it is OE, replace it. Choice is yours.
db057
Sep 4, 2015 07:57 AM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
