Drivers side fan only is turning on
Old Jun 18, 2006 | 08:38 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
i have an 89 iroc 305 tpi and only the drivers side fan is turning on. today on the highway the car was running real close to 245 or so and i dont like that.
basicly my question is what do i look for to determine why the passenger side fan isnt turning on(besides a dead motor(but how should i test for that)).
Old Jun 20, 2006 | 10:49 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
First, try testing the fan motor. Simple way to test the fan motor is to disconnect the leads and jumper straight to battery. If it runs, next test to ensure that you have battery to the relay. If so, replace the relay with a working relay to help determine if the relay might be bad. Also, if your car has A/C, try turning that on to see if the fan runs.
Old Jun 20, 2006 | 11:39 AM
LIDNR2's Avatar
Car: '89 Formula 350, T-Top
Axle/Gears: Stock 3.73's
The right side fan only comes on, when the A/C is on. Wadebryant is right.
You can however, wire the fan to a toggle switch, which is pretty easy.
Old Jun 20, 2006 | 06:26 PM
Engine: 383 HSR EBL
oh i thought that fan also turned on when the engine gets too hot. that explains why it doesnt turn on for me. .
thanks.
Old Jun 20, 2006 | 08:43 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
That fan also runs through a fan switch in the passenger side head. It comes on at 200 and something degrees with the air on or not.
Old Jun 21, 2006 | 07:00 AM
Wadebryant's Avatar
Right, or about 220+. Also check to make sure that the connector to the fan switch is not broken or heat baked.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
