Where Do These Plugs Go?
Old Jun 19, 2006 | 01:37 PM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
Quick question: do both of these plugs circled in the picture below go to the emissions stuff? Would this be causing a Check Engine Light Code 13 (O2 sensor)?
Thanks,
Joe
Old Jun 24, 2006 | 09:55 AM
Vader's Avatar
What are the wire colors on each of the plugs?
Old Jun 24, 2006 | 04:50 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Those are emissions connectors. These shouldn't cause the code. Have you replaced the O2? They are cheap for your car. I replaced my O2 sensor and it still threw the code. I replaced some vacuum hoses and adjusted my carb and it went away.
Old Jun 24, 2006 | 06:32 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
look like the connectors for the air pump and the divertor valve assembly....
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
