Save Your Power Mirror/Lock Wires!
Old Jun 23, 2006 | 03:29 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Maybe this is old news to people, but I wanted to share it in case it helps someone trace or prevent a problem with their power mirrors.
I took apart my PS door panel to replace the handle, outer window felt, and to try and chase down some squeaks and rattles.
I happened to notice that there were two locations where some very thin, delicate wires were resting right on a thin, sharp edge of steel. I imagine that after thousands of miles of vibrating around, the possibility exists for the insulation to be worn through, causing a short and rendering the component inoperable. So, to prevent this, I encased the wires in either wire loom or vacuum line to protect them.
Here are pics to show the two locations. The first is for the power mirror wiring, towards the jamb side of the door, and the second is for the power locks, towards the latch side of the door.
Besides preventing a problem, I thought that if anyone found a short in either of these components, these would be areas worth checking out because of the possibility that the placement of the wires caused a short.
Old Jun 23, 2006 | 04:04 PM
The Phantom's Avatar
Thank you!
Dave
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
