altenator sense wire
Old Jun 24, 2006 | 11:24 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Do i just hook it up to anything that has battery power to it
Old Jun 25, 2006 | 07:19 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Know one knows
Old Jun 25, 2006 | 08:09 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
What are you working on?..vehicle/engine etc.?and what sort of problem are you having?
Old Jun 25, 2006 | 10:04 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
I have only one problem, where does the sense wire go. Please look to the
left and you can see all that information
Old Jun 25, 2006 | 10:25 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Well, are you talking about the no charge signal wire? If so, that goes to a light on the dash.
Old Jun 25, 2006 | 10:32 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
On the alt there is a voltage sense wire where can I connect it, a custom install
It's a cs-144 altenator
Old Jun 25, 2006 | 11:17 PM
jstrdn90rs's Avatar
If you have no dash indicator for it ,then just find a led or warning light and run it to that and you can install the light where ever your little vette desires.
Old Jun 26, 2006 | 12:06 AM
Vader's Avatar
Connect it to any switched ignition source through a 100 ohm resistor.
Old Jun 26, 2006 | 11:58 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
86IROC112
Aug 17, 2015 07:57 PM
