Am I able to wire up my stock OP guage w/o a comp?
Old Jul 12, 2006 | 02:33 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Wondering if anyone has any idea on this. I would like to re-use the stock guage for the time being, I know I know, the guages aren't as acurate as an aftermarket one, but I don't have the money and I am scared to death I will loose pressure and not know it.
I have a 91 Z28 that was a 305 TPI car, and I know the dash is controlled by a voltage regulator, and the gas guage and tach currently work, so I know they are getting power, but would I be able to wire the oil guage back in and will it still work without there comp being used (its a carbed small block).
I read up on the operation of the gauge, and from what it says all I need is a sending unit, instrument panel voltage regulator(IPVR) and a guage wired in series. And from what I understand it is a single TAN wire that runs to the guage and send the info from the sensor. So since the sending unit is the ground and the guage recieves its power from the IPVR all I would need to do is rehook up the tan wire correct??
Old Jul 12, 2006 | 03:12 PM
Also, would I be able to wire the sending unit in as it was before, incase I loose oil pressure the fuel pump will kick off and the engine will stall out due to lack of gas??
Here is a generic wiring diagram, I want to get this right before I go messing things up.
Old Jul 12, 2006 | 03:46 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
yes just wire it back up to the correct sending unit
and thats not how it was originally wired, the oil pressure switch works along side your fuel pump relay
ive thought about wiring it up to rely on the oil pressure switch before, when i was using my remote start alot and not paying attention to the car.. 160k , ya never know when somethings gonna slop into my oil passages and clog something up ;0
err though I should probably also mention the pressure switch has nothing todo with the oil pressure sending unit ;0
Old Jul 12, 2006 | 03:56 PM
so the sensor on the side of the block above the filter DOESNT send a message back to the guage?? Cause from the diagram and the info I got from Mitchells and Alldata both say that switch control both the guage and the fuel pump.....or atleast thats what I understood, so my understanding is wrong?
And the sensor, switch, sending unit are labeled as the same part in the same location.
Old Jul 12, 2006 | 04:00 PM
dr1's Avatar
dr1
Engine: 305 TBI
well that depends I guess on what you were originally asking about
the oil pressure guage, and the oil pressure warning light work off different circuits
Old Jul 12, 2006 | 04:12 PM
I wanted to know if i could use the sensor above the oil filter, which is what the fuel pump back-up power source and where the gauge gets it reading from, and re-wire the guage part back in atleast so I can use the in-dash guage until I can get an aftermarket one.
Old Jul 12, 2006 | 04:16 PM
dr1's Avatar
dr1
Engine: 305 TBI
thats not what your oil pressure gauge gets a reading from, the other line is going to the oil pressure warning light (the 'OIL' light that comes on if you turn your key to on and dont start up car)
the oil pressure gauge uses another sender
Old Jul 12, 2006 | 04:24 PM
But where is that sender at?? On my older TPI car (an 88 Iroc) I had a sender on the block and one underneath the dizzy, and my current 91 didn't have the bronze sending unit back there. But I rewired my 91 TPI car and I left the connector unhooked off the sensor by the oil filter and the car didn't start and the guage showed no movement when it was cranked.
Old Jul 12, 2006 | 04:35 PM
dr1's Avatar
dr1
Engine: 305 TBI
I dont know where your gauge sender is supposed to be, stock location was probably near the distributor
if your car wont start without the switch, your fuel pump relay might not be any good... though the computer controls the relay initially.. so if your computers not hooked up at all I guess that answers that
Old Jul 12, 2006 | 04:44 PM
That was before when it wouldn't start.....NOW it is a carbed, non-computer controlled small block. Nothing stock left under this hood. But when I energized the relay when it was stock the fuel pump primed, and once i figured out the plug was undone and plug it in the car fired up and the guage worked
Ghettobird52
Jul 5, 2024 11:18 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
