Bypassing V.A.T.S 91 Camaro 305
Old Jul 4, 2018 | 04:42 PM
  #101
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Bypassing V.A.T.S 91 Camaro 305
It might be the key reader or passkey module.
https://www.thirdgen.org/forums/elec...pass-vats.html
If your injectors are pulsing after the prime you should check your fuel pressure and possibly the icm.
https://www.thirdgen.org/forums/tbi/...tor-pulse.html
You might try pulling the prom and see if it runs this would bypass the vats but the engine would run poorly. I don’t know if you pour fuel in the tb if the starting would bypass the vats.
Old Jul 4, 2018 | 07:01 PM
  #102
Dirtyocm's Avatar
Im not a real mechanic just trying to help my mother in law. So i making sure i understand this right by grounding the starter relay it will crank but not fire the injectors but by using the resistors it will fire them. I tested the resistance of the key it was 2.88 but did not get any reading at the plug under the column telling me it is the two little wires on the cylinder. Am i correct in this
Old Jul 4, 2018 | 07:05 PM
  #103
Engine: Lb9
Transmission: M20
You correct it’s a key reader issue. You can replace the lock cylinder or bypass the key reader bye installing the appropriate resistance . Sounds like your saying it’s number 9 on the key chart.
https://m.ebay.com/itm/GM-VATS-Bypas...sAAOSwJLJZf7OT
Old Jul 7, 2018 | 01:28 PM
  #104
Dirtyocm's Avatar
Used the #9 resistor to bypass the key. Worked perfectly thanks for the help.
Old Jul 7, 2018 | 03:52 PM
  #105
Engine: Lb9
Transmission: M20
Great news
Old Nov 22, 2018 | 12:55 PM
  #106
230 firebird's Avatar
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
Maybe someone can tell me or post a link for my situation.I want to put a 91 Corvette TPI 350 in my 87 Firebird.I was told I have to get wire harness and ecm from 350 TPI Camaro or Firebird.If I do this,how will I bypass the vats in the 89-92 ecms?My car is a 5 speed and I don't have Vatts on my car.Thanks
Old Nov 22, 2018 | 01:44 PM
  #107
Engine: Lb9
Transmission: M20
there are two options, having the vats programmed out of your memcal chip or installing a hz modulator to send the correct frequency to the ecm.
http://www.bakerelectronix.com/products_vats/
Old Nov 22, 2018 | 02:46 PM
  #108
Engine: sbc 350
Ok,thanks.The link for Baker says they closed may 2018.
84z96L31vortec
Aug 20, 2017 12:16 AM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
