unknown connector
Old Aug 10, 2006 | 09:19 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
unknown connector
i'm swapping out the stock center console in my car, just as i'm about to put the new console back in, i saw this connector next to the shifter & i don't know what it goes to, it's a black rectangle with 5-6 wires coming out of it in a line, purple, yellow, orange, blue, green & purple with a white stripe, i think are the colors (probably not in that order), the purple & yellow wires are a little bigger than the rest, what is it suppose to hook to?
Old Aug 10, 2006 | 09:23 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Sounds like the neutral saftey switch connector. Should connect to the shifter. Mike
Old Aug 11, 2006 | 02:25 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
my car is a manual,
Old Aug 11, 2006 | 02:36 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Do you have a pic???
Old Aug 11, 2006 | 07:00 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
i don't have any pics
Old Aug 11, 2006 | 09:02 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
At first I was thinking console clock but I don't belive that was avaible in any Firebirds(plus to many wires for the ****).Did you car come from the factory as a manual trans?if not this would take it back to the neutral safety switch(the switch and wiring might be a standard part of all interior harness).The only other thing I can think of is the connector for power mirror switch.
Old Aug 12, 2006 | 03:51 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
that's what i was thinking... but my car doens't have power mirrors
my car is a factorey manual
should i just leave it unhooked?
Old Aug 12, 2006 | 03:54 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
What about wires for the hatch release?
Old Aug 12, 2006 | 11:36 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
the hatch release button is mounted in the dash & the wiring doesn't run down the center, i know because my old car had it,
Old Aug 12, 2006 | 11:59 PM
racnboy87's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
i just went out and looked and its not plugged into anything and i have a 5 speed also. i have my whole dash and console out and have noticed alot of connectors not plugged in. the only thing i can think of is GM made a wiring harness that thay used in differnt models.
Old Aug 13, 2006 | 12:15 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Some cars were pre-wired for options they didn't recieve.
My 87 had a auto shifter harness and wiring for power mirrows... it had neither.
The neutral saftey wiring is tied (parallel) to the clutch switch wiring though
My 91 has the power window/lock breakers in the fuse panel... neither present in the car.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
