ALDL Check Engine from the ECM
Old Sep 15, 2006 | 02:56 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I converted my 91 TBI car to an 87 TPI engine and wiring harness. Everything works and it has aftermarket gauges, but the time has come to wire up the ALDL connector. My plan is to put it in a panel under the the dash on the passenger side with the check engine light on a 3 way switch (off, check engine, and Serial Data) so I won't have to mess with the AB jumper anymore, but retain the ALDL port so I can use my serial data reader. I need to know what the wiring is coming from the ECM so I can splice my ALDL in on that side. Keep in mind the car wiring is for a 1991 TBI car and the harness is from a 1987 Formula 350 Firebird. Thanks in advance everyone!
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
