No Dash lights?
Old Sep 27, 2006 | 08:25 PM
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
No Dash lights?
Headlight switch has power and everything out of it has power, there is one bulb missing from dash(check engine ight) I just got this car. What should I check?
Old Sep 27, 2006 | 08:28 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
welcome to the fourm, you need to post car type year what lights are out(dash?) also try the search bot at the top right of screen i have answered this a few time along with many others Good luck
Old Sep 27, 2006 | 08:34 PM
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
It is an 86 Iroc Z28-couldnt find anything when I searched
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
And it is just the dash lights
Old Sep 27, 2006 | 08:35 PM
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
and it is just the dash lights
Old Sep 27, 2006 | 08:36 PM
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
Old Sep 27, 2006 | 08:54 PM
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
Sorry-it kept telling me to retry in 30 seconds
Old Sep 28, 2006 | 12:20 AM
GTAfanatic's Avatar
first things first you should try to replace the switch it self
2nd make sure that all the bulbs are not blown this happened in my blazer
Old Sep 28, 2006 | 11:46 PM
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
I replaced the switch- also the gear indicator in center console light does not come on so it is a common wire that controls all off the interior light. I have the wiring schematic but dont see the problem.
Old Sep 29, 2006 | 07:55 AM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
I may have jsut encounterred this same problem last night....
I was hooking up some gauge lights that I removed when I took out my interior and all the sudden I hear a click and smell burnt stuff....next thing I know, wires that used to read 12 to 14 volts are now reading 44 volts with the key in the on positions. None of my interior lights work now except for the overhead light.
Old Sep 29, 2006 | 11:46 PM
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
Mine does not read 44 volts but like you said, the only working light is the overhead. Let me know if you figure something out before I do.
Old Oct 1, 2006 | 06:32 AM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Did the lights work when you bought the car? And also does it have a aftermarket radio now?
Old Oct 1, 2006 | 08:30 PM
spncrwhls's Avatar
Car: 86 Iroc Z28
Transmission: 700R
Axle/Gears: OE
Actually it turned out to be pretty simple, I think. The 5 amp fuse was missing. Yeah i know it was a real bonehead thing to miss- coulda swore I checked it like 3 times. Maybe it was a combo of several things. I dont know, except like it still needs 5 bulbs too. And then I still have to put it back together.
Old Oct 2, 2006 | 11:41 PM
GTAfanatic's Avatar
thanks for the update i hate when people leave open threads
Old Oct 3, 2006 | 02:07 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Ahh. Yea. We blew mine changing it over to LED's the other day. Bugger tested as positive to the multimeter too. So it took like three checks up until I did a visual. Taking it apart is easy. Take out your hush panel (panel under the dash) then take out the panel that sits under your steering column. All of these are 8mm I believe. Drop the steering column (13 or 14 mm) it's two nuts. Real easy. Remove the screws over the panel, torx 20 I think. Remove the screws holding the glass one. 7/32 I think. Remove the two screws holding the metal reflector on, also 7/32. On the bottom there should be two 10mm nuts holdding the whole assembly in place. Remove them, if you're lucky, neither of the bolts behind them is freewheeling, so it should be easy. Hardest part is getting behind there and removing that damn speedometer cable. There is a place to push on the retaining hook, but it's rotated towards the bottom left of the cluster. Just feel around back there until you get it, and Pop! There you have your cluster.
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
